https://designers-guide.org/forum/YaBB.pl Simulators >> Logic Simulators >> how to print integer in the verilog module https://designers-guide.org/forum/YaBB.pl?num=1533749648 Message started by liletian on Aug 8th, 2018, 10:34am |
Title: how to print integer in the verilog module Post by liletian on Aug 8th, 2018, 10:34am Hi All I write the following module comparator, In the testbench, I would like to monitor integer i, when I try to print out the interger using the following statement, it does not work. Is there a way to keep track of the interger in the testbench? Thank you very much, module comparator(stag,ptag,tag_equal); parameter n=16; input [n-1:0] stag,ptag; output tag_equal; reg tag_equal; integer i; // initial begin // tag_equal<=1'b1; // end always @(stag or ptag) for(i=n-1;i>=0;i=i-1) begin: sweep if((stag[i]^ptag[i])) begin tag_equal<=1'b0; // break; // disable sweep; end else tag_equal<=1'b1; end endmodule module test_comparator(); parameter n=16; reg [n-1:0] A,B; wire tag_equal; comparator #(n) com(.stag(A),.ptag(B),.tag_equal(tag_equal)); initial begin $monitor($stime, " stag=%h,ptag=%h,tag_equal=%b, i=%b", A,B,tag_equal,com.i); #10; A=16'h000A; B=16'h000B; #10; A=16'h000B; B=16'h000B; end // initial begin endmodule |
Title: Re: how to print integer in the verilog module Post by Andrew Beckett on Aug 9th, 2018, 4:26am It works for me (using XCELIUM 18.10). I suspect that your problem is that you're only seeing the final value of i at each time - that's because the for loop increments i at the same time, with no delay - and $monitor outputs only the final value. From the IEEE 1364-2001 LRM (section 17.1): Quote:
If (for example) I add a delay: Code:
and then also change the final #10 to a #20 to allow sufficient time for the loop to complete, I then get: 0 stag=xxxx,ptag=xxxx,tag_equal=x, i=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx 10 stag=000a,ptag=000b,tag_equal=x, i=00000000000000000000000000001111 11 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000001110 12 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000001101 13 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000001100 14 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000001011 15 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000001010 16 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000001001 17 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000001000 18 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000000111 19 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000000110 20 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000000101 21 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000000100 22 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000000011 23 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000000010 24 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000000001 25 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000000000 26 stag=000a,ptag=000b,tag_equal=0, i=11111111111111111111111111111111 30 stag=000b,ptag=000b,tag_equal=0, i=00000000000000000000000000001111 31 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000001110 32 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000001101 33 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000001100 34 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000001011 35 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000001010 36 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000001001 37 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000001000 38 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000000111 39 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000000110 40 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000000101 41 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000000100 42 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000000011 43 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000000010 44 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000000001 45 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000000000 46 stag=000b,ptag=000b,tag_equal=1, i=11111111111111111111111111111111 Regards, Andrew. |
