https://designers-guide.org/forum/YaBB.pl Simulators >> Logic Simulators >> how to save simulation data and re-view the data again and again? https://designers-guide.org/forum/YaBB.pl?num=1534614158 Message started by liletian on Aug 18th, 2018, 10:42am |
Title: how to save simulation data and re-view the data again and again? Post by liletian on Aug 18th, 2018, 10:42am HI all how can you save the data to a specific file so I can access later and all the time? One more question is what is a more convenient way to probe signal? right now, I send the waveform to another screen to do it. Two questions here. 1. is there a more convenient way to do it? 2. how to do it in script? Thank you very much |
Title: Re: how to save simulation data and re-view the data again and again? Post by deba on Aug 20th, 2018, 2:20am You can specify the waves directory using the "database" command. |
