Design Languages >> Verilog-AMS >> Negative power for flicker_noise()
https://designers-guide.org/forum/YaBB.pl?num=1545748007
Message started by cheap_salary on Dec 25th, 2018, 6:26am
Title: Negative power for flicker_noise()
Post by cheap_salary on Dec 25th, 2018, 6:26am
See Junction diode by Marek Mierzwinski.
http://www.designers-guide.org/VerilogAMS/semiconductors/diode/diode.va
Negative power is used for flicker_noise() in this code like following.
Code:
if (Id > 0)
  AbsId = pow(Id, af);
else
  AbsId = -pow(-Id, af);
I(anode, internal) <+ flicker_noise(kf * AbsId, 1.0, "flicker");
What does this negative power mean ?
I think negative power is nonsense.
BTW, ahdllint of Cadence Spectre does not give any warning fir this negative power.
Title: Re: Negative power for flicker_noise()
Post by Geoffrey_Coram on Jan 2nd, 2019, 1:03pm
I suspect simulators probably take the absolute value of the first argument to flicker_noise (as well as white_noise).
Post by Ken Kundert on Jan 2nd, 2019, 4:03pm
I am not really sure what you mean by negative power.
Perhaps your question regards this code:
Code:
if (Id > 0)
� AbsId = pow(Id, af);
else
� AbsId = -pow(-Id, af);
This is basically a hack to handle negative currents. The pow() function requires its first argument to be non-negative, but you don't want to simply pass the first argument through an abs() function, because that changes the behavior of the model in a non-physical way.
To understand this, consider the case where af=1. In this case, the pow() function becomes a no-op, and the above collapses down to:
Code:
AbsId = Id
If you were to add an abs() function to protect the pow() function, and then set af=1, the equivalent would be
Code:
AbsId = abs(Id)
This is clearly a different behavior. To see that, consider the case were Id is a sinusoid. In the first case you are modulating the noise with a pure tone, in the second you are modulating it with a rectified sinewave, which has a high harmonic content but no component at the fundamental frequency.
If you are not comfortable with this model, just assume af=1 and simplify it down to:
Code:
I(anode, internal) <+ kf*flicker_noise(Id, 1, "flicker");
-Ken
Post by cheap_salary on Jan 2nd, 2019, 10:30pm
I mean -pow()
Post by Ken Kundert on Jan 2nd, 2019, 11:11pm
Did my response answer your question? If not, perhaps you can explain why the
minus sign in from of the pow() function bothers you?
-Ken
Post by cheap_salary on Jan 3rd, 2019, 8:37am
Ken Kundert wrote on Jan 2nd, 2019, 11:11pm:
No.
Yes.
AbsId<0 for Id<0.
Post by Ken Kundert on Jan 3rd, 2019, 3:51pm
AbsID is a poor choice of names for that variable.
Post by Geoffrey_Coram on Jan 8th, 2019, 8:40am
Indeed, AbsId is misleading.
As I mentioned in my first response, I expect simulators probably take the absolute value of the argument to flicker_noise -- for standard spice small-signal noise analysis.
For PNoise (or HBNoise), Ken's point comes into play:
Post by cheap_salary on Jan 11th, 2019, 5:11am
Quote:
white_noise( PSD [ , "name"])
PSD is the power spectral density of the source where PSD is specified in units of A2/Hz or V2/Hz.
flicker_noise( power, exp [ , "name"])
power is the power of the source at 1 Hz.
[Conclusion]
Argument of Small-Signal Noise Sources in Verilog-A is power.
However negative power reflects polarity of Noise Source.
This is true for white_noise().
Quote:
I(anode, internal) <+ white_noise(2 * `P_Q * Id, "thermal");
Here PSD is not always positive.
flicker_noise(-pow()) is equivalent to -flicker_noise(pow()).
Quote:
if (Id > 0)
else
is equivalent to
Quote:
if (Id > 0)
� I(anode, internal) <+ flicker_noise(kf * pow(abs(Id), af), 1.0, "flicker");
else
� I(anode, internal) <+ -flicker_noise(kf * pow(abs(Id), af), 1.0, "flicker");
