https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> why using an inverter with hysteresis https://designers-guide.org/forum/YaBB.pl?num=1546194034 Message started by bki on Dec 30th, 2018, 10:20am |
Title: why using an inverter with hysteresis Post by bki on Dec 30th, 2018, 10:20am What is the use of an Inverter with Hysteresis/ what are the benefits compared to just an Inverter without Hysteresis? Is it an stability benefit if i have such an Inverter with Hysteresis followed by a second Inverter? |
Title: Re: why using an inverter with hysteresis Post by James_T on Jan 21st, 2019, 9:15am I think it's stability issue. It can help us to reduce mis-operation. The schmitt trigger is for this reason. |
Title: Re: why using an inverter with hysteresis Post by Jacki on Mar 13th, 2019, 7:59am I think you are talking about the Schmitt trigger, you may want to remove any ripple and glitches from your output. |
