https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> opamp simulation https://designers-guide.org/forum/YaBB.pl?num=1555340071 Message started by blue111 on Apr 15th, 2019, 7:54am |
Title: opamp simulation Post by blue111 on Apr 15th, 2019, 7:54am For improving phase margin of opamp3.asc , I use an extra series 5k resistor R1 to put a zero near the unity gain frequency. but then, good accurate resistor is hard to fabricate. So, let me ask: anyone have any idea on how to replace both the ideal current source and the extra resistor with a mosfet in ohmic region without using any extra bias voltage source ? In other words, is it possible to use constant gm bias circuit in both opamp3.asc and opamp.asc circuit ? |
Title: Re: opamp simulation Post by dog1 on Apr 29th, 2019, 8:37am Hi blue111, I am not sure if this really correspond to the question you are asking, but I guess you could split the bias branch into 2, one for Nmos and one for Pmos, and copy the current into both branches. Then you could use normal gm-transistor. As for the detail of the bias, note that in a feedback system, Ids15->Ids11->Ids12->Ids13->Ids14, I guess if you bias M15 in a fixed ratio with the gm-transistor (through 2 diode connected transistor in serial, for example), that might work? PS: I know my drawing is terrible... |
