https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> caculate Zin of a HF rectifier using ADS https://designers-guide.org/forum/YaBB.pl?num=1580805819 Message started by ShiGa on Feb 4th, 2020, 12:43am |
Title: caculate Zin of a HF rectifier using ADS Post by ShiGa on Feb 4th, 2020, 12:43am Hello everyone, I‘m a student majoring in EE. I want to design a wide-band high-efficiency rectifier for wireless power transmission based on the paper below. I used the same diode as it said: HSMS286c in HFDiode lib. I used the variable 'f' to simulate the Zin in different frequencies. However, the verdict is different from the paper's result and I have no idea why. The imag part is positive but it should be negative. Perhaps I set something wrongly. What should I do about it?Can any of you help? Thank you so much. ![]() |
