https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> symmetrical op amp with asymmetrical dc operating point (SOLVED) https://designers-guide.org/forum/YaBB.pl?num=1646176686 Message started by Fausto on Mar 1st, 2022, 3:18pm |
Title: symmetrical op amp with asymmetrical dc operating point (SOLVED) Post by Fausto on Mar 1st, 2022, 3:18pm Hello everyone, first thank you for reading my post. I have a problem, I am trying to characterize a fully differential miller opamp. However, although the design is completely symmetrical, the operating point of one of the branches is different from the other and I don't understand why. In the following image you can see what I mean: ![]() Due to this asymmetry the common mode control circuit is not working well. Any idea or suggestion is welcome. Edit: Excuse me, I already found the error, I had the bulk of a badly connected transistor |
