https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Physical Verification, Extraction and Analysis >> GCD fill layer in 28nm technology https://designers-guide.org/forum/YaBB.pl?num=1658714126 Message started by vlsi_design on Jul 24th, 2022, 6:55pm |
Title: GCD fill layer in 28nm technology Post by vlsi_design on Jul 24th, 2022, 6:55pm Hi, In addition to active, poly and metal fill layers, do I need to do GCD fill layer for a typical 28nm cmos technology? The kit documents do not clearly explain it. What are the additional fill layers needed a typical 28nm cmos technology? |
Title: Re: GCD fill layer in 28nm technology Post by ajithkv on Jan 26th, 2024, 8:10am Can you clarify what is the GCD layer, please? Generally dummy fill rule deck will generate all necessary fill layers for a given design. |
