Design >> RF Design >> Direct Conversion Receiver
https://designers-guide.org/forum/YaBB.pl?num=1686148875
Message started by Marios on Jun 7th, 2023, 6:41am
Title: Direct Conversion Receiver
Post by Marios on Jun 7th, 2023, 6:41am
Dear all,
I am simulating a direct-conversion Rx. It comprises an LNA followed by a passive mixer followed by a "current-input" baseband filter (By current input I mean input stage is transimpedance amp) as shown in Fig A.
Instead of using PSS/PAC/PNOISE to simulate everything, I tried to create an sp-model of the baseband filter using an SP analysis. As shown in Fig B, I run an SP saving all S-parameters along with noise of the filter in the 2-port.
Then I used the 2-port to load the mixer and run PSS/PAC/PNOISE as shown in Fig C. For some reason, I do not get the same results (I mean the difference are some dBs in gain and NF). My fundamental is 2.5GHz and the 2-port contains data up to 20GHz so I guess this is enough for 7th harmonic.
Any ideas of what could I get wrong is much appreciated.
Regards
Marios
