https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Deviation of simulated Jc to calculated Jc , plus a question k-cycle jitter https://designers-guide.org/forum/YaBB.pl?num=1687809915 Message started by jitter_grg on Jun 26th, 2023, 1:05pm |
Title: Deviation of simulated Jc to calculated Jc , plus a question k-cycle jitter Post by jitter_grg on Jun 26th, 2023, 1:05pm This is a plot of a 7 stage inverter based ring oscillator period jitter variance simulated using pss/pnoise. The k-cycle param is used from the direct plot main form. Question 1: I can understand at Fmin of 100 due to flicker noise there is more deviation (on high side) compared to sqrt{k} in Jc. But, why the deviation to the other side (low side) as Fmin increases >10MHz ? Question 2: This circuit has a free running oscillator, followed by a sync divider in reality. But, when simulating osc+divider the pss was not converging. Hence, the oscillator in itself was simulated and k-cycle accumulation was used to infer the divide-by-k function of the eventual sync divider. Is that a fair assumption, ignoring any inherent noise form divider ? Appreciate your time and any advice you might have. |
Title: Re: Deviation of simulated Jc to calculated Jc , plus a question k-cycle jitter Post by Ken Kundert on Jun 26th, 2023, 2:38pm I'm afraid I have no explanation. For the k-cycle jitter to stay constant or decrease with k implies that the signal is locking to a stable signal. Does such a signal exist in your simulation? |
Title: Re: Deviation of simulated Jc to calculated Jc , plus a question k-cycle jitter Post by jitter_grg on Jun 26th, 2023, 2:52pm No such stable signal exists in the deck. I assume you mean another frequency tone which is non-drifting and stable. The deck has supply/gnd and 7-stage inverter based ring oscillator for these numbers. The ring itself is a free-running oscillator. Anyway that was the question 1. Interesting that it only happens at high enough value for Fmin. At slightly lower Fmin values Jc matches sqrt{M} factor, and at still lower Fmin Jc deviates from sqrt{M} factor due to Jee. The last two parts are as per expectation. **** Any comment on question 2 ? Basically for a free running osc+ sync divider combo, is the jitter at sync divide-by-k output same as looking at jitter at oscillator output with k-cycle param in direct plot main form ? |
Title: Re: Deviation of simulated Jc to calculated Jc , plus a question k-cycle jitter Post by Ken Kundert on Jun 26th, 2023, 3:17pm I can't really comment on that as I am not familiar with how the data is processed to extract the k-cycle jitter. |
