https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> ring oscillator https://designers-guide.org/forum/YaBB.pl?num=1701236909 Message started by theICdesigner on Nov 28th, 2023, 9:48pm |
Title: ring oscillator Post by theICdesigner on Nov 28th, 2023, 9:48pm Hi, I want to design a ring oscillator with inverter with MOSFETs. I know the R and C can be used to determine the frequency but how do I calculate resistance of each inverter stage if the transistors also influence equivalent resistance? |
Title: Re: ring oscillator Post by ICDESIGNKING on Jan 23rd, 2024, 5:25pm :D Calculation the output resistance of each stage using definition. Especially for the ac source connected @ the output. |
