https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Sparse matrix https://designers-guide.org/forum/YaBB.pl?num=1049500807 Message started by vova on Apr 4th, 2003, 4:00pm |
Title: Sparse matrix Post by vova on Apr 4th, 2003, 4:00pm I am using Sparse V1.3a and need to get a pointer to an existing element knowing only row and column numbers. Actually Sparse which I am using does not have a function for that. So I just want to know if such a function already exist, or I am forced to write my own, modifing spPrint()? Thanks, Vova. |
Title: Re: Sparse matrix Post by Ken Kundert on Apr 4th, 2003, 4:17pm The function spGetElement allows you to get a pointer to an existing element knowing only the row and column number. It will, however, create the element if it does not already exist. -Ken |
Title: Re: Sparse matrix Post by vova on Apr 4th, 2003, 5:06pm I don't want to waste memory. I have a look at spGetElement. It seems I can use spcFindElementinCol() with NO as a last argumen. But I am cunfused, will it work for col=row? Thanks a lot, Vova. |
Title: Re: Sparse matrix Post by Ken Kundert on Apr 8th, 2003, 3:24pm There is a function in the Spice3 compatibility code in spSMP.c that does what you want. It is SMPfindElt(). Do you have that code? -Ken |
Title: Re: Sparse matrix Post by vova on Apr 10th, 2003, 1:55pm Yes, I have spsmp.c. Thanks for letting me know about SMPfindElt(), now I am using this function. Vova. |
Title: Re: Sparse matrix Post by rf-design on Oct 13th, 2003, 2:06am I am interessted in circuit simulation implementation. Does anybody now about 1. Solving sparse matrix by combinations of direct and iterative method. Where pivot ordering and selection generate side information which part to solve direct and which iterative. 2. Is there a reuse of pivot information while processing different transient steps? 3. Does the pivot selection and reordering change much at circuit discontiniousities? 4. Does circuit simulator implementations exist based on state variable approach. How these implement rank deficiencies? |
