Simulators >> Circuit Simulators >> temperature simulation
https://designers-guide.org/forum/YaBB.pl?num=1049911144
Message started by aceman on Apr 9th, 2003, 3:25am
Title: temperature simulation
Post by aceman on Apr 9th, 2003, 3:25am
how can i do temperature simulation in cadence. I designe circuit with temp shutdown, and i need simulate temp hysteresis. Please help me. beginner.
Title: Re: temperature simulation
Post by Mighty Mouse on Apr 9th, 2003, 10:55am
I assume that you want to do a DC simulation in Artist. If so, it's a piece of cake.
Just use the "choose analysis" form to select DC analysis, and push the button to enable sweeping, and select temperature sweep.
To see the hysteresis, you will need to run two analyses. One where you sweep the termperature up, and the other were you sweep it down.
- MM -
