https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> power amplifier simulation in SpectreRF https://designers-guide.org/forum/YaBB.pl?num=1050171389 Message started by tony on Apr 12th, 2003, 11:16am |
Title: power amplifier simulation in SpectreRF Post by tony on Apr 12th, 2003, 11:16am Hello, Can anyone direct me to any resources (and the Cadence manual is not one, I checked) that can help me design a power amplifer using SiGe HBT ? I cannot find any tutorials, papers or anything that uses spectre. Issues are load pull, modellling, and so on Any help with this is apprecated. |
Title: Re: power amplifier simulation in SpectreRF Post by Thomas_Hansson on Apr 14th, 2003, 11:00am Hello I know your issues and I guess that e.g. ADS is more used for traditional power amplifier design. However if good models exist for your SiGe HBT amplifier of course also Cadence/spectreRF will do the job. Models of the transistors are of course the most important thing and all standard models today like BSIM 3.X.X exist for most of the processes I have used. I think you can find some application notes at sourcelink (sourcelink.cadence.com) about how to use portadapter and contours to do load pull for example. I usually use s-parameters analysis for the linear simulations and then pss (periodic steady state) or transient for the non-linear effects like compression... Regards Thomas |
Title: Re: power amplifier simulation in SpectreRF Post by tony on Apr 14th, 2003, 3:40pm hi thanks for the reply. i went over to sourcelink.cadence.com and found the whole thing a bit daunting. any tips of suggestions on how to find things just a little easier ? thanks! |
Title: Re: power amplifier simulation in SpectreRF Post by Thomas Hansson on Apr 15th, 2003, 10:40am Hello again I tried and by some reason it's not working for internet explorer however using Netscape I managed to get in. If I search for "power contours" I get this article that can be quite useful. Also in the version (IC5.0) there is new function added for power added efficiency and similar unctions typical for power amplifiers. Of cource this can be expressed using the calculator in all other cases. Thomas |
Title: Re: power amplifier simulation in SpectreRF Post by tony on Apr 17th, 2003, 3:35pm hello, thank you for the reply. would it be possible to obtain your email address so i could possibly email you with my concerns and issues ? or is it better to post them here ? by the way, i do not have IC5.0. thank you again and have a great day! regards, tony |
Title: Re: power amplifier simulation in SpectreRF Post by Thomas_Hansson on Apr 22nd, 2003, 4:50am thomashansson_se@yahoo.se |
Title: how to check stability of PA in Cadence? Post by rfic on May 19th, 2003, 11:28am hi, PA guys i'm also working on PA design with Cadence. I notice we can use "power contours" & "reflection contours" in "PSS" analysis to simulate PA. As far as "reflection contours", it's for stability issues of PA. But i'm NOT quite understand how it works, and what's difference between "seperate terminals" & "single terminals", anyone has this expereince or know where i can find more detail information? thanks |
