https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Want to plot impedance over frequency domain https://designers-guide.org/forum/YaBB.pl?num=1059682754 Message started by Mo on Jul 31st, 2003, 1:19pm |
Title: Want to plot impedance over frequency domain Post by Mo on Jul 31st, 2003, 1:19pm I used smartspice to simulate a circuit. I am wondering how I can get a plot of impedance over the frequency domain. Do I need to write any scripts in C++/Java/C simulate the circuit hundreds of times and pick each voltage and current to find the corresponding impedance? If so, how? I will really appreciate any ideas or advance. THanks Mo |
Title: Re: Want to plot impedance over frequency domain Post by Mighty Mouse on Aug 1st, 2003, 10:08am Drive the port for which you want the impedance with 1 A current source and perform an AC analysis. Then plot the port voltage. The impedance is V/I, and I is 1, so the magnitude and phase of the voltage will be identical to the magnitude and phase of the port impedance. |
Title: Re: Want to plot impedance over frequency domain Post by Mo on Aug 4th, 2003, 7:09am Thanks for your reply. But the capacitance/resistance/inductance are dependent to the frequency. Can I still do it with ac analysis? To make it clear, the magitude of some of the resistance, capacitance and inductance are a function of frequency. Thanks. |
Title: Re: Want to plot impedance over frequency domain Post by Mighty Mouse on Aug 4th, 2003, 2:56pm Sure, just perform an AC analysis where you sweep the frequency. Try it, it is easy. |
Title: Re: Want to plot impedance over frequency domain Post by Mo on Aug 5th, 2003, 6:47am mmmm......but i am not sure how to make the arbitrary value of resistance work.... say one of the resistance is (freq/x+y)...... How can I let the simulator know that freq is the frequency that it sweeps thru? sorrie, i am a newbie....thanks very much |
