https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> How to export data (ploting)?? https://designers-guide.org/forum/YaBB.pl?num=1060673745 Message started by Aigneryu on Aug 12th, 2003, 12:35am |
Title: How to export data (ploting)?? Post by Aigneryu on Aug 12th, 2003, 12:35am Hi! Recently I need to export Spectre simulation results such as signal spectrum or waveform for further process. I can use ideal sampler included in the standard ahdl lib to export time domain waveform. However, I do not know how to export frequency data from certain simulation bench such as PSS or PNoise or even PSS waveform. Does anybody know how to export these data in two dimensional format just as the waveform or spectrum plot?? |
Title: Re: How to export data (ploting)?? Post by Vladimir Fomin on Jan 7th, 2004, 12:41am Using "print" button of calculator you can print any waveform with any step into a file. Then you can import this data into another tool. |
