https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Monte carlo simulation https://designers-guide.org/forum/YaBB.pl?num=1066446592 Message started by forghani on Oct 17th, 2003, 8:09pm |
Title: Monte carlo simulation Post by forghani on Oct 17th, 2003, 8:09pm Hello, I have a question about the effect of circuit parameters' change in monte carlo simulation. Suppose I simulate a circuit for 100 times, and I see an unordinary situation in run 8. Then I change a transistor parameter or a currrent source value (no change in the topology). Afterthat, I run the monte carlo simulation again like the first experiment. 1. Is the randomness in both experiments the same? 2. If the randomness does not remain the same, what I can do to make the randomness the same and then run the monte carlo only for the run that had a problem after the circuit modifications, to see if I have solved the circuit problem? Sincerely, Pooya |
Title: Re: Monte carlo simulation Post by Paul on Nov 11th, 2003, 11:52pm You shall use the SEED of your simulator. If SEED is the same, the results of both simulations will be the same. I don't know for Spectre, but ELDO offers an option to set the number of the run you want to perform. I guess Spectre should offer the same possibility. Check your simulator manual. Paul |
