https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Simulation problem in the Cadence ams suite https://designers-guide.org/forum/YaBB.pl?num=1070147753 Message started by aravind on Nov 29th, 2003, 3:15pm |
Title: Simulation problem in the Cadence ams suite Post by aravind on Nov 29th, 2003, 3:15pm Hey everyone We are running ncsim from the cadence ams suite. our code is in verilog ams. The problem is that the compiling and the elaborating processes are fine but with the simulation, we are getting the following error. ERROR! cdsInit has not been called ERROR! can't determine installation root from PATH ncsim: *internal* (rts_seghandler - SIGSEGV unexpected violation pc=0xfeab2fb0 addr=0x00000000). Please help. thanks aravind |
Title: Re: Simulation problem in the Cadence ams suite Post by Andrew Beckett on Dec 1st, 2003, 6:05am Do you have the LDV stream (<ldvInstdir>/tools/bin) in your UNIX path? Or are you referring to the full path to the executable? Are you using the NC-Verilog integration, or are you using AMS Designer? I'd certainly make sure that you have the software in the path - that would explain the can't determine installation root from path error. Not sure about the segmentation fault though. Which versions are you using (icfb -W, ncsim -version)? Regards, Andrew. |
Title: Re: Simulation problem in the Cadence ams suite Post by Geoffrey_Coram on Feb 13th, 2004, 9:39am aravind wrote on Nov 29th, 2003, 3:15pm:
I've seen this message trying to start Spectre from the command line, when the binary cds_root was not in my path or in the same directory with the spectre link/executable. |
