https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Zero of a common source amplifier https://designers-guide.org/forum/YaBB.pl?num=1077622869 Message started by ram on Feb 24th, 2004, 3:41am |
Title: Zero of a common source amplifier Post by ram on Feb 24th, 2004, 3:41am Hi, I have a common source amp, with a pmos diode load. According to analysis zero should be at gm of input_transistor/cgd of input_transistor. If cgd=cgdo*w; where cgdo=3.1500E-10 (from model file) and w=1u, cgd = 0.315 fF and if gm=97.7e-6, Zero should at 310.19 G rad/sec But the star-hspice pz analysis shows a zero at 45.7 G rad/sec. I am not able to figure out the reason behind this difference. Can anybody please helpme with this. Thanks and Regards ram |
