https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> comparing different bias current https://designers-guide.org/forum/YaBB.pl?num=1077823279 Message started by nobody on Feb 26th, 2004, 11:21am |
Title: comparing different bias current Post by nobody on Feb 26th, 2004, 11:21am Hi, all Is it possible to make a circuit that can compare different bias currents and that ouputs the maximum of compared bias currents ? thanks |
Title: Re: comparing different bias current Post by fehler on Sep 22nd, 2004, 7:39am Hi, I do think it is possible. You can use current comparator to give a logic output, which controlling a set of switchs. I think you can find a solution in this way. For current comparator, please ref to Baker, Li, Boyce's analog design textbook. regards! |
