https://designers-guide.org/forum/YaBB.pl Modeling >> Semiconductor Devices >> Silvaco's models https://designers-guide.org/forum/YaBB.pl?num=1078170984 Message started by August West on Mar 1st, 2004, 11:56am |
Title: Silvaco's models Post by August West on Mar 1st, 2004, 11:56am Has anyone taken a serious look at the Silvaco models (http://www.silvaco.com/downloads/verilogADownloads.html). If so, how do they look? I took a careful look and the diode, and it does not seem ready for prime time. It had a couple of issues. 1. Several standard parameters are missing (eg, ibv, xti) 2. vj parameter is misnamed phi, and given wrong default value. 3. noise model is missing. 4. The current used to determine the size of the diffusion capacitance includes the current through the junction and diffusion capacitances, which it should not. Are the other models is a similar state? If so, it would seem it indicate that Silvaco is not yet using these models as their base models. -August |
Title: Re: Silvaco's models Post by Geoffrey_Coram on Jul 9th, 2004, 8:33am August - You are correct that most of the models are not ready for prime-time. Many of the problems arise from the lack of certain features in Verilog-A. For example, the BSIM3 model is also lacking noise, because you can't get the derivatives for the noise equation 8/3 kT (gm+gds+gmbs) without manually computing them -- defeating the purpose of a higher-level language. BSIM3 did seem useable for transient, though. There is a subcommittee (of which I am the chairman) proposing extensions to Verilog-AMS to handle these features. Another sort of problem is that found in the MOS level=3 model. It uses a capacitance-based model, which can result in lack of charge conservation. The subcommittee is not proposing extensions to handle this, since "everyone knows" that's a bad way to write a model now. -Geoffrey |
