https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> parametric simulation in Spectre https://designers-guide.org/forum/YaBB.pl?num=1078967402 Message started by jimmy on Mar 10th, 2004, 5:10pm |
Title: parametric simulation in Spectre Post by jimmy on Mar 10th, 2004, 5:10pm Hi all, I have a problem with parametric simulation in Spectre. Whenever I start to run parametric simulation, there will be a window pop-up every time when one run is over, the window basically tells you how many runs you still have. It is painful that this window always show up on top of the window I am working on. What a annoying interference! Does some one know how to get rid of this pop-up window during the simulation. Many thanks, jimmy li |
Title: Re: parametric simulation in Spectre Post by Andrew Beckett on Mar 10th, 2004, 10:46pm Jimmy, Unfortunately it can't be turned off right now. There's a PCR for this: PCR: 482903 Title: Parametric Analysis output window should stay iconified Also, it should take note of having auto-update off (covered in the same PCR). If you contact Cadence via your normal support channel, then additional customers who are asking for this to be fixed will influence the priority for getting this minor irritation fixed. Best Regards, Andrew. |
