https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> opamp'problem in the sc network https://designers-guide.org/forum/YaBB.pl?num=1081388363 Message started by alice_alice_nc on Apr 7th, 2004, 6:39pm |
Title: opamp'problem in the sc network Post by alice_alice_nc on Apr 7th, 2004, 6:39pm KEN: I want to ask you another question about that there is DC problem in the opamp enbeded in the sc network , the output DC of the opamp is 600m or so ,so it affected the ac characteristic . How I can solve the problem of the output dc ? If I used the big capacitor ,I can remove the 600mV ' dc, but I can not used so large capacitor. |
Title: Re: opamp'problem in the sc network Post by Mighty Mouse on Apr 7th, 2004, 8:15pm Alice, What is causing the 600mV DC offset? - MM - |
Title: Re: opamp'problem in the sc network Post by alice_alice_nc on Apr 8th, 2004, 12:57am The architecture of the opamp is a one stage folded cascoded opamp ,pmos input , and the output is from the four transistor,so there is 600mv dc problem . |
