https://designers-guide.org/forum/YaBB.pl Design Languages >> VHDL-AMS >> Variable clock delay modelling https://designers-guide.org/forum/YaBB.pl?num=1082558417 Message started by Tom Johnson on Apr 21st, 2004, 7:40am |
Title: Variable clock delay modelling Post by Tom Johnson on Apr 21st, 2004, 7:40am Hi, Im involved in a synchronizer project and need to model the system. I have 1 clock signal running at XMHz and need to create a phase shifted version of it, where the phase shift varies sinusoidally between +- Ømax. Basically i need to create a block of code that performs a variable phase shift Ø(t), as shown below and am wondering is this possible? Thanks in advance Tom variable delay block _________________ | | Ø(t) = sin(t) |________________| |
Title: Re: Variable clock delay modelling Post by George Suarez on Apr 29th, 2004, 5:24pm Hi, Here is a code that I wrote for random numbers between A and minus A. architecture random of random_num is constant K : real := 1.3806503e-23; signal Vth_op: real := 0.0; signal rand: real := 0.0; signal clk : bit :='0'; entity ... is... end entity; architecture ideal of .... is signal rand1,rand2: real := 0.0; signal clk : bit :='0'; begin clk <= not clk after Tshrn; process variable unf : real; variable seed1:integer := 2; variable seed2:integer := 123123123; begin wait on clk; Uniform(seed1,seed2,unf); rand1 <= ROUND(unf*10.0); --Multiply unf by 10 to obtain integer end process; break on rand1; process variable unf : real; variable seed1:integer := 2; variable seed2:integer := 123123123; begin wait on clk; Uniform(seed1,seed2,unf); rand2 <= unf; end process; break on rand2; between_A_n_minusA == ((-1.0)**rand1)*rand2*A end random; This code may be freely distributed, I create it for a course project. Hope it helps. gEoRgiE |
