Measurements >> RF Measurements >> RF Probing on Aluminum pads
https://designers-guide.org/forum/YaBB.pl?num=1083872736
Message started by Fei on May 6th, 2004, 12:45pm
Title: RF Probing on Aluminum pads
Post by Fei on May 6th, 2004, 12:45pm
I did some measurements on chip, which has aluminum pads for probing.  Probe contact was a headache for me.
Anyone has suggestions on what type of probe should be using in this case.
Thanks
Title: Re: RF Probing on Aluminum pads
Post by caduser on Aug 17th, 2004, 8:03pm
Use cascade microtech G-S-G probes.
I think the standard pitch is 100um.
Post by MTYang on Sep 20th, 2005, 6:44pm
I assumed you have used the AuBe probe for Au pad probing. Please try the W probe which developed for Al pad, respectively. You can get it from Cascade or GGB.
