https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Spectre simulation for audio classD amplifier https://designers-guide.org/forum/YaBB.pl?num=1088027640 Message started by berserk on Jun 23rd, 2004, 2:54pm |
Title: Spectre simulation for audio classD amplifier Post by berserk on Jun 23rd, 2004, 2:54pm Hi, I am simulating a classD audio PWM amplifier loop with spectre. The idle channel pss condition of the amplifier is a 50% duty cycle squarewave. I get the PSS analysis to converge properly under this condition. I have a few questions : ??? 1) When I do PNOISE on the ouput (a 50% duty cycle squarewave), does it reflect an idle channel measurement? 2) Since the output is really a continuous time signal, should I use the PNOISE option "sources"? 3) When using this option does spectre do a noise calculation all over the periodic signal? 4) Since there is a comparator in the analog loop, does the PNOISE still hold valid? TIA for any advice/suggestions/answers.... ;D |
