https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> how to plot VCO tuning characteristics spectreRF? https://designers-guide.org/forum/YaBB.pl?num=1089398832 Message started by EE student on Jul 9th, 2004, 11:47am |
Title: how to plot VCO tuning characteristics spectreRF? Post by EE student on Jul 9th, 2004, 11:47am I am designing a LC VCO in 0.18u CMOS. How do I plot the tuning characteristics of the VCO ( Freq vs control voltage) in spectre RF? thanks |
Title: Re: how to plot VCO tuning characteristics spectre Post by froggy on Jul 19th, 2004, 8:43pm Hope the following is useful to you. You can run a transient simulation and use the "clip" and "frequency" special function in the calculator from Analog Circuit Design (ACD) to determine the frequency of the VCO at a particular control voltage. Example: "frequency(clip(VT("/net065"),20n ,50n))" Next you can use parametric analysis to run the VCO simulation for a different set control voltage, after the simulation is done, you can plot the VCO tuning charactertics. |
Title: Re: how to plot VCO tuning characteristics spectre Post by Andrew Beckett on Jul 21st, 2004, 12:46am A few things you can do: a) A sweep of the control voltage and then do an autonomous PSS to get the oscillator frequency. This is probably quite expensive in terms of simulation time though. b) A transient analysis, using the Verilog-A model freq_meter from ahdlLib at the output of your oscillator - this measures the times between zero-crossings and outputs this as a frequency. The benefit of using the Verilog-A model is that the crossing is resolved in the simulator, and so minimises interpolation error. However, you need to sweep the control voltage slowly over time to avoid impacting the instantaneous frequency too much. You can then change the x-axis to be the control voltage, and plot the frequency against that. c) As an alternative to using freq_meter, a calculator function that I wrote can be used. I can't post it here (it is too long, and the system won't let me post it), but it is available on http://sourcelink.cadence.com as solution number 11015938. Regards, Andrew. |
