https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> How to make zero lammbda?? https://designers-guide.org/forum/YaBB.pl?num=1089810254 Message started by Ragadast on Jul 14th, 2004, 6:04am |
Title: How to make zero lammbda?? Post by Ragadast on Jul 14th, 2004, 6:04am Somebody can tell me which parameters have I to modificate to make zero lammbda in BSIM3v3 model for Spectre? thanks |
Title: Re: How to make zero lammbda?? Post by Andrew Beckett on Jul 14th, 2004, 1:34pm Why on earth would you want to do this? If you want ideal behaviour, it makes no sense to use a complex model such as bsim3v3. Andrew. BTW, I think the parameter is probably pclm, but without looking at the model equations I'm not certain that this is the parameter, nor if it is the only parameter. |
