https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Spectre PSS analysis for switched cap circuits https://designers-guide.org/forum/YaBB.pl?num=1092706349 Message started by Mohit on Aug 16th, 2004, 6:32pm |
Title: Spectre PSS analysis for switched cap circuits Post by Mohit on Aug 16th, 2004, 6:32pm I am a newbie working with spectre. I read few posts on this forum and it is suggested that using PSS analysis is much faster for CMFB circuits. I just wanted to make sure if this generalizes to all circuits that have capacitors and a clock. I have made a simple integrator circuit with capacitors as switch and was wondering if I could make simulations faster. Also what do i do if I need to transient simulation of the above circuit, as what i can see in spectre is we have only pss, pac and pnoise. Also does any one has the basic tutorial of these analysis (pss et al), coz when i choose pss as analysis, it asks me fundamental tone, name, expr, value, signal etc. (i m not really sure how to choose all this; Sorry I am a newbie) |
Title: Re: Spectre PSS analysis for switched cap circuits Post by Andrew Beckett on Aug 19th, 2004, 10:08am You should read Ken's paper: http://www.designers-guide.com/Analysis/sc-filters.pdf Andrew. |
