https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Sample and hold circuit https://designers-guide.org/forum/YaBB.pl?num=1093229921 Message started by vivekrc on Aug 22nd, 2004, 7:58pm |
Title: Sample and hold circuit Post by vivekrc on Aug 22nd, 2004, 7:58pm I designed a sample and hold circuit by using a capacitance, a analog switch and a voltage follower. This design works fine for an input frequency of 5 MHz and a clock frequency of 100 MHz. What should i do in order to run the same design for an input frequency of 125MHz and a sampling frequency of 2.5GHz. I have designed an analog switch using six transistors(3 PMOS and 3 NMOS) |
