Design >> RF Design >> Fractional Divider in Reference Path of PLL
https://designers-guide.org/forum/YaBB.pl?num=1094802750
Message started by Daniel Nobonzo on Sep 10th, 2004, 12:52am
Title: Fractional Divider in Reference Path of PLL
Post by Daniel Nobonzo on Sep 10th, 2004, 12:52am
Hi,
I wonder if there is any drawback in placing a fractional divider (noise, spurs, ..) in the reference path, i.e. after the crystal, instead of after the VCO.
Thanks for your comments.
Dan
Title: Re: Fractional Divider in Reference Path of PLL
Post by emad on Sep 10th, 2004, 8:01am
It is actually both!
A fractional divider based on DS modulation is pretty noisy. That is because the quantization noise shows as shaped noise with 20*(n-1) dB/dec, where n is the modulator order. This noise at the reference will be further magnified by 20*log(N), where N is the feedback divider ratio.
Same happens for spurs.
For the reference section you want a quiet configuration. You simply can't afford to mess up there.
Post by strabush on Jan 10th, 2005, 5:58am
Matter of fact, A DDS as the reference is exactly that.
