https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> Generate jittery clock in cadence https://designers-guide.org/forum/YaBB.pl?num=1095070343 Message started by srihari on Sep 13th, 2004, 3:12am |
Title: Generate jittery clock in cadence Post by srihari on Sep 13th, 2004, 3:12am Hi all, Could any one help me how to generate a jittery clock of specified value in cadence? Thanks and regards, Srihari |
Title: Re: Generate jittery clock in cadence Post by Jitter Man on Sep 13th, 2004, 8:46am See http://www.designers-guide.com/Analysis/PLLjitter.pdf. Particularly section 7. [glb]Jitter Man[/glb] |
Title: Re: Generate jittery clock in cadence Post by August West on Sep 13th, 2004, 10:22am You can also find models that exhibit jitter at www.verilog-ams.com. -August |
Title: Re: Generate jittery clock in cadence Post by srihari on Sep 14th, 2004, 11:05pm Thankyou All, I have a few doubt, Initially I generated the jittery clock using verilogA and also refering through the paper mentioned, but the project I am working on has very high divide by ratio, for example If we have a clock of 27Mhz (jittery of 100ps) and divider by 27000 we get a clk output from the divider of 1Khz with jitter, This clk is applied as reference to my PFD, while I need to simulate for a longer duration of 150 - 200ms (milli-sec). If I plot the eye diagram of the clk output(27Mhz) for smaller duration say 100us, the jitter is around 100ps, if I plot the same for a longer duration say 1ms, jitter is 1-1.2ns and for 100ms duration its too high. What I require is a clk of 27MHz with jitter of around 100ps, even if i run the simulation for 100 or more milli sec. The jitter should be with in the range, If I am wrong please correct me. Thanks and regards, Srihari |
