https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Run time error in Verilog AMS https://designers-guide.org/forum/YaBB.pl?num=1097291584 Message started by Vivek Chandrasekhar on Oct 8th, 2004, 8:13pm |
Title: Run time error in Verilog AMS Post by Vivek Chandrasekhar on Oct 8th, 2004, 8:13pm I got this error when i was simulating my 4 bit DAC code. The error is out_scaled = out_scaled + ((V(bit2) > vtrans) ? 4 : 0);: Expecting only branch or node type argument The code is as under `include "disciplines.vams" `include "constants.vams" module dac (out,bit3,bit2,bit1,bit0); output out; input bit3,bit2,bit1,bit0; electrical out; logic bit3,bit2,bit1,bit0; parameter real vref = 1 from [0:inf); parameter real trise = 0 from [0:inf); parameter real tfall = 0 from [0:inf); parameter real tdel = 0 from [0:inf); parameter real vtrans = 1.2; real out_scaled; // output scaled as fraction of 16 analog begin out_scaled = 0; out_scaled = out_scaled + ((V(bit3) > vtrans) ? 8 : 0); out_scaled = out_scaled + ((V(bit2) > vtrans) ? 4 : 0); out_scaled = out_scaled + ((V(bit1) > vtrans) ? 2 : 0); out_scaled = out_scaled + ((V(bit0) > vtrans) ? 1 : 0); end endmodule I would be grateful to anyone who could point out my error. Thanks. Vivek |
Title: Re: Run time error in Verilog AMS Post by Mighty Mouse on Oct 9th, 2004, 12:38am V() is an electrical access function. It should only be applied to electrical signals. bit2 is not electrical, it is logic. You would access the value of bit2 without the access function. So you should use ... out_scaled = out_scaled + ((bit2 > vtrans) ? 4 : 0); |
Title: Re: Run time error in Verilog AMS Post by Andrew Beckett on Oct 12th, 2004, 1:58pm In fact, it should probably be: Code:
No point comparing a logic signal to see if it is greater than vtrans... Regards, Andrew. |
Title: Re: Run time error in Verilog AMS Post by jbdavid on Nov 1st, 2004, 7:54pm And actually if you declared that as a 4bit wide bus, rather than 4 signals: you can make this much simpler.. module dac (output out, input [3:0] bit); electrical out; logic [3:0] bit; parameter real vref = 1 from [0:inf); parameter real trise = 0 from [0:inf); parameter real tfall = 0 from [0:inf); parameter real tdel = 0 from [0:inf); parameter real vtrans = 1.2; // not needed for d2a real out_scaled; // output scaled as fraction of 16 integer iout = 0; // output without x or z (init to 0) always @(bit) if (^bit ==! 1`bx or ^bit ==! 1`bz) iout = bit; analog begin out_scaled = out/16.0; V(out) = vref*transition(out_scaled, tdel, trise,tfall); end endmodule --- PS I do use some of the verilog2001 enhancements.. they work in NCsim -ams.. jbd |
Title: Re: Run time error in Verilog AMS Post by jbdavid on Nov 1st, 2004, 7:56pm sorry that should have been outscaled = iout/16; JBD |
