https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Transistor Layout https://designers-guide.org/forum/YaBB.pl?num=1097698718 Message started by logan on Oct 13th, 2004, 1:18pm |
Title: Transistor Layout Post by logan on Oct 13th, 2004, 1:18pm I was told that the NMOS (or PMOS) transistor in my LNA design should be laid in roughly a square shape. I have not been able to find information elsewhere that confirmed this as a fact. Can someone confirm the optimum layout (Narrow/Broad/Square) and why. Many Thanks |
Title: Re: Transistor Layout Post by Paul on Oct 27th, 2004, 8:26am Hello Logan, you have to consider several aspects and decide which are most important to your design. a) flicker noise is lower for wider W*L, i.e. function of 1/(W*L) b) matching is proportional to 1/(W*L), but for very narrow or very short devices also to 1/W+1/L c) with very short channels, you can experience velocity saturation, degrading the transconductance and increasing the channel thermal noise coefficient I don't know if this fully answers your question... Paul |
Title: Re: Transistor Layout Post by logan on Nov 12th, 2004, 2:02pm thanks paul. I think i know what you are talking about. We did have a visiting professor who told me that it should be square in shape as a rule of thumb. unfortuantely he visits us no more and no in-house experts in this field. so I am just feeling my way around things. I do have though another question which I shall also post at the top of the forum as a new topic Q. is it not abnormal that I get a difference of 9 dB in losses between an ideal inductor and one from the model library ( i am using 3 metal cmos 0.35u) thanks |
