Design Languages >> Verilog-AMS >> Verilog-A model for VCO
https://designers-guide.org/forum/YaBB.pl?num=1099466381
Message started by Rohan Batra on Nov 2nd, 2004, 11:19pm
Title: Verilog-A model for VCO
Post by Rohan Batra on Nov 2nd, 2004, 11:19pm
I am trying to write a verilog-A model for a VCO. But instead of the voltage out vs voltage in relationship, I want to model a frequency out vs voltage in relationship. Is there anyway to describe the output as a "frequency" discipline type. I know that you can declare something as a "voltage" or "phase" in verilog-A.
Title: Re: Verilog-A model for VCO
Post by sheldon on Dec 28th, 2004, 4:46pm
Rohan,
  Do it all the time, but I have always just output the
frequency as a voltage. Never actually seen anyone
create a separate discipline to do this. Have you tried
defining a new discipline for frequency in the discipline.vams,
(for Spectre) file? If you update the file you file, you need
to point to the correct one in module.
                                                        Best Regards,
                                                          Art Schaldenbrand
Post by Eugene on Jan 2nd, 2005, 9:51pm
I also usually just represent frequency with a voltaqe. The trick is to choose the right frequency units (GHz, MHz, etc.) to keep numbers reasonable. I use voltage primarily because that node is a convenient place to insert a zero-voltage DC voltage source, with AC magnitude=1, to compute loop gain. I think you will have to create a Verilog A module for this source if you use a frequency discipline. However, if you use voltage, you can use the Spectre primitive. Another reason I usually choose the electrical discipline is that, being an electrical engineer, it is often easier for me to introduce filters using RLCs instead of creating another verilogA block for a Laplace transform. I also wonder if the simulation runs faster with primitives instead of Laplace blocks.
Post by gogomi on Feb 28th, 2005, 9:42pm
Hi,
Just wondering if you use voltage to represent frequency, then how do you model the phase?
Do you also use voltage?
gogomi
