https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> THA Design https://designers-guide.org/forum/YaBB.pl?num=1099484997 Message started by codec on Nov 3rd, 2004, 4:29am |
Title: THA Design Post by codec on Nov 3rd, 2004, 4:29am Hello, I met difficulty in THA design of the pipelined ADC. The T/H circuit has a worst case THD of 72dB@1.875MHz(fs=60MHz) but 55dB@58.125MHz(fs=60MHz). In such case, what should I focus on in order to improve the performance? Any adivce or recommended paper? Thanks a lot! |
Title: Re: THA Design Post by ywguo on Nov 5th, 2004, 6:23am Hi, First of all, I want to know how do you measure THD of the THA. :) When I simulate THA, I measure THD using FFT analysis. It is important to control the start time and step of FFT because the Track and hold is a one-order sample and hold. Do you think so? About your problem, THD decreases as the input frequency increases because of finite input bandwidth. I think you should lower the on-resistance of input switch or lower the capacitance of the sampling capacitor. :) Best regards, Yawei |
Title: Re: THA Design Post by codec on Nov 5th, 2004, 7:51am Thanks, ywguo! I also use FFT to measure THD. I set fin=fs/32 and take 64 points or above to calculate FFT. The Fu of THA amp is about 600MHz and it is a flip-around THA structure. I also suspected that Ron of SW was too high, but when I used ideal SW with Ron as low as 50~100ohm, the THD was not improved. (It is also this simulation let me select CMOS SW instead of boostrapped SW) What about your simulation result? BTW, I use Spectre . |
Title: Re: THA Design Post by microant2000 on Nov 7th, 2004, 10:49pm hello, I want to know the resolution of your THA,and what do you mean in your article "55dB@58.125MHz",it seems that the measure is in the undersampling condition. Do you measure the sample switch' THD? it will limit the THA performance.about the on-resistance , i think you should make it constant ,not lower. sorry, my English is poor, i hope you can understand my ideal. :D Best regards, microant |
Title: Re: THA Design Post by codec on Nov 9th, 2004, 3:25am Thanks, MicroAnt It is true that constant Ron(Vin) is of most importance. These days, I chaned the switch to bootstrapped type and archieved a better THD of 65dB@61.875MHz. (undersampling mode) But I am wondering whether such simulation is necessary. |
Title: Re: THA Design Post by ywguo on Nov 15th, 2004, 3:53am Hi, Codec, Have you measured the on-resistance of the switches? I wonder the relationship between the resistance and the THD. The THD of the THA is necessary because it decides the THD of whole ADC. :) Yawei |
Title: Re: THA Design Post by codec on Nov 16th, 2004, 7:23pm Hello, Yawei Ron is around 60~100ohm in my design. I mean whether it is necessary for me to simulate the circuit under the condition of "undersampling"? In real application, would such case occur? |
Title: Re: THA Design Post by ywguo on Nov 19th, 2004, 7:16pm Codec, Ron is around 60~100Ohm for bootstrapped swtich? That is very near Ron in my design, which is a 40MHz, 10bit IF-samping ADC. The undersampling depends on your application. For eg., an IF-sampling ADC used in DVB-C demodulator. What is your application? Best regards, Yawei |
Title: Re: THA Design Post by codec on Nov 30th, 2004, 2:52pm Hi, Yawei Sorry for my late reply. I was busy working these days. My current design is for the request of a custom. It is said to be a video application. BTW, have you done the post-layout simulation? When I was doing the post simulation on the THA block, I found that the THD degradated for near 10dB. I am trying to find the problem. Have you any ideas? Thanks. |
