https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> porblem in running Dracula https://designers-guide.org/forum/YaBB.pl?num=1101003653 Message started by jimmy on Nov 20th, 2004, 6:20pm |
Title: porblem in running Dracula Post by jimmy on Nov 20th, 2004, 6:20pm I got an error message when I want to debug LVS errors after running Dracula. Can not find BOUNDARY.DAT at /tmp/iqDir/a023352/Dracula/ ! ERROR: No LAYDE.DIS in the input paths ! Please do Setup ! But I do have the LAYDE.DIS file in my running directory. Does anyone have idea of what is the problem? Thank you, jimmy li |
Title: Re: porblem in running Dracula Post by Andrew Beckett on Nov 21st, 2004, 10:17pm Do you have KEEPDATA=YES or KEEPDATA=INQUERY in your *DESCRIPTION block? Are you doing Tools->Dracula Interactive->Setup->LVS? Regards, Andrew. |
Title: Re: porblem in running Dracula Post by ywguo on Nov 22nd, 2004, 7:54am Jimmy, According my experience, if KEEPDATA=SMART, all the files storing the LVS error message are removed. So you may not run dracula interactive. Pls set to KEEPDATA=INQUERY or KEEPDATA=YES. Good luck! Yawei |
Title: Re: porblem in running Dracula Post by jimmy on Nov 22nd, 2004, 10:39am Andrew and Yawei, Thank you so much. Now it works after I set KEEPDATA=YES. The default value in our prcess kit is SMART. Thank you again, jimmy li |
