https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> simulation tools for sigma-delta modulator https://designers-guide.org/forum/YaBB.pl?num=1101992778 Message started by GaAs on Dec 2nd, 2004, 5:06am |
Title: simulation tools for sigma-delta modulator Post by GaAs on Dec 2nd, 2004, 5:06am Hi, Could you pls recommend some behavior simulation tools for sigma-delta modulators Thanks |
Title: Re: simulation tools for sigma-delta modulator Post by Andrew Beckett on Dec 2nd, 2004, 9:57pm One suggestion is to look at http://www.designers-guide.com/Analysis/. There is a paper there for analysing noise in signal delta modulators, using spectreRF. Regards, Andrew. |
