https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Named Port Association in Verilog-AMS https://designers-guide.org/forum/YaBB.pl?num=1103442432 Message started by Vikram Srinivasan on Dec 18th, 2004, 11:47pm |
Title: Named Port Association in Verilog-AMS Post by Vikram Srinivasan on Dec 18th, 2004, 11:47pm Hi I was designing an RC network and I decided to have 3 modules in my source file-2 for definitions of the resistor and capacitor and the main module where instances of the R and C were created(with the appropriate interconnection). This is the code I wrote: module rescap(posr,negc); electrical posr,negr,negc; resistor res(.p(posr),.n(negr)); capacitor cap(.pos(negr),.neg(negc)); endmodule module resistor(p,n); parameter real rn=1k from [1:inf]; electrical p,n; analog begin V(p,n) <+ rn*I(p,n); end endmodule module capacitor(pos,neg); parameter real c=100 from [1:inf]; electrical pos,neg; analog begin I(pos,neg) <+ c*ddt(V(pos,neg)); end endmodule My test bench file looks like this: module rctest(posr,negc); electrical posr,negc; wire negr; resistor #(.rn(1000)) res(p,n); capacitor #(.c(100)) cap(pos,neg); vsource #(.type("sine"),.dc(0),.ampl(5),.freq(5000)) vin(posr,negc); endmodule Now when I compile this, I get an error message that "Named Port Association is not valid for analog primitives in Affirma-AMS". I am confused. I thought named port association was valid in V-AMS. Am I missing something? |
Title: Re: Named Port Association in Verilog-AMS Post by Mighty Mouse on Dec 20th, 2004, 9:58am Named port associations seem like they should work. Kundert included an example of it in his book (see listing15 in chapter 4 at http://www.designers-guide.com/Books/dg-vams/index.html), and he claims they were all tested in AMS-Designer. Perhaps the fact that you have chosen names for your modules that are exactly the same names used for the built-in primitives is confusing things. Try myres rather than resistor, etc. |
Title: Re: Named Port Association in Verilog-AMS Post by Vikram Srinivasan on Dec 20th, 2004, 11:15am Thanks MightyMouse !! I'l try that ! |
