https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Current Transformers https://designers-guide.org/forum/YaBB.pl?num=1104728228 Message started by sardineta on Jan 2nd, 2005, 8:57pm |
Title: Current Transformers Post by sardineta on Jan 2nd, 2005, 8:57pm Hello everyone! have a happy new year!!! I have a current transformer which generates an induced AC signal: 60 Hz Amplitud may vary from 0 to 10V. The transformer has a resistance of 900 ohm http://my.netomat.net/sardineta/Current_Transformer I would like to read this signal in order to get it into an ADC. The ADC I will use is inside a microcontroller, PIC16F870. I have already done a circuit, but I think it requires a special attention that I don't know. I am not sure if the design of the differential amplifier is correct and also I would like some advices to create the layout, I did one but it does not work well. I did it in a protoboard and worker well but in the layout it fail, I will upload the layout latter, i don't have the file right know. other questions are: Does the power supply is right? The differential amplifier and all other circuits are right? what consideration to create the PCB I have to take? Here is the project http://my.netomat.net/sardineta/Current_Transformer Thanks in advanced, I will appreciate your help! |
