https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Find MOS operation region in spectre calculator https://designers-guide.org/forum/YaBB.pl?num=1106251852 Message started by gogomi on Jan 20th, 2005, 12:10pm |
Title: Find MOS operation region in spectre calculator Post by gogomi on Jan 20th, 2005, 12:10pm Hi, Does anyone know the meaning of operation region from spectre calculator? The device operation region was represented by some numbers and I have no idea what is these numbers mean. Here is the command in spectre: OP("/N0" "region"). Thanks! gogomickey |
Title: Re: Find MOS operation region in spectre calculato Post by mohammad on Jan 20th, 2005, 1:51pm Hi, I think the numbers are as follows: 0 off 1 Triode 2 Saturation 3 Subthreshold M.H. |
Title: Re: Find MOS operation region in spectre calculato Post by gogomi on Jan 20th, 2005, 9:52pm Got it! Thank you very much! gogomickey |
Title: Re: Find MOS operation region in spectre calculato Post by Ken Kundert on Jan 21st, 2005, 1:04am If you run "spectre -h dev" where 'dev' is the name of the device for N0, you will see the complete list of possible values for the region parameter. The number corresponds to the index for the values in this list starting from 0. So 0 would correspond to the first item in the list, 1 to the second in the list, etc. -Ken |
