https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> "amsdirect not found" https://designers-guide.org/forum/YaBB.pl?num=1106845193 Message started by akvarma on Jan 27th, 2005, 8:59am |
Title: "amsdirect not found" Post by akvarma on Jan 27th, 2005, 8:59am Hi, I am running ic5033/ld51 and I am trying to run Cadence tutorial for AMS Designer. When I do a run from AMS->Design Prep->Run, I get an error saying "amsdirect not found". I have setup all the paths and I can even see amsdirect from the command line. Not sure what I need to do for this thing to have a successful run. Thanks for any help in advance. Ambrish. |
Title: Re: "amsdirect not found" Post by Andrew Beckett on Jan 28th, 2005, 10:51pm Hi Ambrish, The only references I could find to this problem were a little vague as to the cause - except they did indeed get solved ultimately somehow! One case was because the product had not been installed (don't think that's your problem), one was because of a lack of AMS_environment license feature, and one was fixed by installing a later hotfix. Perhaps you could get IC5033 USR3? Regards, Andrew. |
Title: Re: "amsdirect not found" Post by akvarma on Jan 31st, 2005, 11:48am Thanks for that. Well - its not as easy as it sounds to install USR3 sitting behind a university machine. Something inside me says that I am not setting the LD_LIBRARY_PATH environment correctly. The tutorial asks to "Add the location of the AMS Designer software libraries to the search path specified with the LD_LIBRARY_PATH environment variable. setenv LD_LIBRARY_PATH ${AMSHOME}/tools/lib:${CDSHOME}/tools/lib" Has anybody run the tutorial successfully? Thanks. Ambrish. |
Title: Re: "amsdirect not found" Post by Andrew Beckett on Jan 31st, 2005, 9:39pm I have run it successfully before. I don't think LD_LIBRARY_PATH would necessarily have anything to do with it - but you might as well try it. Andrew. |
Title: Re: "amsdirect not found" Post by akvarma on Feb 18th, 2005, 9:35am Just for the records, We fixed the error with the help of Cadence support. Seems there was a bug in IC5033 USR2. We had to change directory permissions for the amsdirect executable and thats it. Thanks. Ambrish. |
