https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> How to generayte uramp usingSpectreRF?? https://designers-guide.org/forum/YaBB.pl?num=1107336662 Message started by fchirouf on Feb 2nd, 2005, 1:31am |
Title: How to generayte uramp usingSpectreRF?? Post by fchirouf on Feb 2nd, 2005, 1:31am Hello all! I need to use uramp function in spectreRF, so I don't know who to generate it. So, as well know that uramp is a specifique function to SPICE (berkeley). Can any body tel me how to generate this function by SpectreRF. Advance thinks |
Title: Re: How to generayte uramp usingSpectreRF?? Post by Andrew Beckett on Feb 2nd, 2005, 10:02am I did some searching on google, having never come across uramp before. As far as I can see from http://www.beigebag.com/case_logical_3.htm it is simply: uramp(f(a)) == f(a) if f(a)>0, else 0. http://www.anasoft.co.uk/Spice3F5Manual.html says the same thing. So in spectre, that would be: Code:
Regards, Andrew. |
