https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Global and Local Sources https://designers-guide.org/forum/YaBB.pl?num=1108691590 Message started by ramus12 on Feb 17th, 2005, 5:53pm |
Title: Global and Local Sources Post by ramus12 on Feb 17th, 2005, 5:53pm Hello all! I am woking on a multi bit adder. This requires a hierarchial approach and I have declared the Vdd and Gnd pins as Local in my basic single-bit adder, the buiding blocks of my circuit. I know that the convention says that It should be declared as a global variable esp when we use a modular approach. But I have already started my layout and want to know if I can from this point onwards declare the Vdd and Gnd as global, the lower heirarchy Vdd and Gnd pins being local. Will this cause errors on simulations? HOw does a local Vdd differ from a GLobal Vdd, ultimately the routing is anyways going to be performed using the layout tools which connects all the Vdd pins in the circuit right? thanks all! Ramus |
