https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Cadence PLL library https://designers-guide.org/forum/YaBB.pl?num=1109299666 Message started by gogomi on Feb 24th, 2005, 6:47pm |
Title: Cadence PLL library Post by gogomi on Feb 24th, 2005, 6:47pm Hi, I am trying to use the "example_phase_domain" of Cadence PLL library to run some test cases but I found out that it's not that straight forward as I thought. Does anyone here have used it successfully? Could you please let me know your settings? Thank you very much! gogomi |
Title: Re: Cadence PLL library Post by Eugene on Mar 7th, 2005, 8:53pm You should not have to change the numerical settings. As for instrument states, there might be a .artist_states directory next to or in the pllLib. I don't remember and don't have access to the tool right now. Which example and which analysis are you trying to run? |
