https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> spectre circuit simulator https://designers-guide.org/forum/YaBB.pl?num=1109451125 Message started by ramus12 on Feb 26th, 2005, 12:52pm |
Title: spectre circuit simulator Post by ramus12 on Feb 26th, 2005, 12:52pm Hello all! What is the best way to specify inputs for simulation of a 64 bit adder using Spectre circuit simulator? thanks! Ramus |
Title: Re: spectre circuit simulator Post by kamesh419 on Mar 1st, 2005, 7:45am ramus12 wrote on Feb 26th, 2005, 12:52pm:
First try to make a file in ASCII with digital inputs for A, B and Cin individually. Then you can convert that file into voltage sources (Time-Value pairs) using any scripting language. Then you can use 'vpwlf' source in cadence to read directly from a file that you have created. This according to me is the simplest way. probably some body else can throw some more light on this. Bye kamesh. |
