https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Analysing waveforms using spectre. https://designers-guide.org/forum/YaBB.pl?num=1111521469 Message started by kamesh on Mar 22nd, 2005, 11:57am |
Title: Analysing waveforms using spectre. Post by kamesh on Mar 22nd, 2005, 11:57am Dear all, I have a circuit and I simulate it using Affirma Analog Circuit Design Environment. I get a wave form window with Voltage(V) on the Y axis and Time(t) on the X-axis. Now what i want is to export this data to a file like thing on which i can make further operations. A file which may contain data of Time and Voltage values. Any one can throw some light on this and tell me how I can go about this. Thanks and Regards, Kamesh. P.S: I tried posting the same question in comp.cad.cadence. But unfortunately no one replied :-[. Think there is some problem with google groups. |
Title: Re: Analysing waveforms using spectre. Post by Eugene on Mar 22nd, 2005, 4:11pm If I understood your question, you have two options: 1. Use "printvs" in the waveform calculator to dump the data to a file. This becomes cumbersome if you have a large number of points because the waverform calculator will assume you did not really want to store so many points and ask that you use the command line. 2. Insert a VerilogA block that strobes and records the data of interest. I've used this many times. It works great as long as you are doing a Spectre transient analysis. |
Title: Re: Analysing waveforms using spectre. Post by kamesh419 on Mar 23rd, 2005, 8:32am Thank you very much Eugene, it really helped me.. Bye, kamesh. |
