https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> How to do parametric sweep in Spectre language? https://designers-guide.org/forum/YaBB.pl?num=1111659379 Message started by James on Mar 24th, 2005, 2:16am |
Title: How to do parametric sweep in Spectre language? Post by James on Mar 24th, 2005, 2:16am I want to know the syntax of Parametric Sweep in Spectre language. I need to add Parametric Sweep commonds in a spectre simulation file, but dont know how. Does anybody know?. I mean do not use the simulation tool of Analog Design Enviroment, just insert the commonds into the spectre simulation file. Thanks |
Title: Re: How to do parametric sweep in Spectre language Post by Andrew Beckett on Mar 24th, 2005, 5:32am Code:
Regards, Andrew. |
Title: Re: How to do parametric sweep in Spectre language Post by James on Mar 24th, 2005, 5:07pm Thanks, but I need more details. For Example: I want to change the voltage of signal Vctr from 0V to 1V with the step 100mV. At each voltage, I need to simulate the ckts 100ns. How to write the code to achieve the above setting? Many thanks |
Title: Re: How to do parametric sweep in Spectre language Post by James on Mar 26th, 2005, 5:11pm Who know how to write these commonds? Thanks |
Title: Re: How to do parametric sweep in Spectre language Post by Andrew Beckett on Mar 27th, 2005, 10:17pm Well, reading the documentation (cdsdoc) would have allowed you to work this out for yourself. For those unable to research simple things themselves, here's what you'd do: Code:
Regards, Andrew. |
Title: Re: How to do parametric sweep in Spectre language Post by James on Mar 28th, 2005, 4:53pm :-[ I'm so shame |
