https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> A simple question. https://designers-guide.org/forum/YaBB.pl?num=1111764532 Message started by James on Mar 25th, 2005, 7:28am |
Title: A simple question. Post by James on Mar 25th, 2005, 7:28am For a common Source stage Amplifer with Resistive Load Rd. It is said in Razavi's book that: For large values of Rd, the effet of channel length modulation in the transistor becomes significant. Why does the effet of channel length modulation become large for Large Rd? many thanks |
Title: Re: A simple question. Post by Ken Kundert on Mar 25th, 2005, 9:27am The model of the output of a common source amplifier is a controlled current source in parallel with a resistor, ro. The channel length modulation determines the size of the resistor. The more channel length modulation, the smaller the resistor. If the load resistor Rd is small, then it overwhelms ro. If the load resistor is large, then Rd does not overwhelm ro, meaning that ro affects the overall gain, distortion, etc. -Ken |
Title: Re: A simple question. Post by James on Mar 25th, 2005, 4:51pm Thanks, your explanation is very clear. I fully understand it now |
