https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Synthesis of HDL codes https://designers-guide.org/forum/YaBB.pl?num=1111864025 Message started by vikramts on Mar 26th, 2005, 11:07am |
Title: Synthesis of HDL codes Post by vikramts on Mar 26th, 2005, 11:07am Can somebody tell me what options we have at present to fabricate systems developed using HDLs like Verilog-AMS and VHDL-AMS? Do we have examples of codes which have been synthesised using automated technologies? |
Title: Re: Synthesis of HDL codes Post by Andrew Beckett on Mar 29th, 2005, 8:39pm If the Verilog-AMS or VHDL-AMS is digital (i.e. normal Verilog or VHDL) and is at Register Transfer Level (RTL), then it can be synthesized using tools like Cadence's RTL Compiler, or Synopys' Design Compiler. I don't know of any tools to synthesize AMS language designs, except to use human designers! It's significantly harder to do. It would be possible if you restricted the synthesis to a small number of circuit types, I guess, but even then I don't know if anyone is doing this commercially yet. Regards, Andrew. |
Title: Re: Synthesis of HDL codes Post by vikramts on Mar 30th, 2005, 7:02am Thanks Andrew! It helps me to confirm these things from authentic sources ! Regards Vikram |
